Universal Dialog Box
My universal dialog box is now working.
Message 1 of 15
(4,639 Views)
The problem I always had with universal dialog boxes was that they universally didn't fit in with my UI.
Bill
CLD
(Mid-Level minion.)
Message 2 of 15
(4,605 Views)
With this one, you can plug in any set of buttons.  Also, you can have a custom entry field.
Message 3 of 15
(4,574 Views)
So, how is this thing used? I could not drop it on the BD, but I could insert it as a VI and apparently its an express VI. But I cannot open its properties and cannot run it (LV2021).
When run:
Must say I'm a bit reluctant to Express-VIs, but I'm still interested to see what your VI can do.
Certified LabVIEW Architect
Message 4 of 15
(4,569 Views)
Same here. Thought i didn't wire something, so i wired everything, but the error still pops up (LV 2019).
I didn't install it tho, just dropped on block diagram.
Message 5 of 15
(4,556 Views)
*Facepalm* I opened the README-file but I did not read it...
The installer completely hanged LV though. Tried installing again without mass-recompile and got:
Removed all installed files in user-lib. Tried opening install.vi again and it stays at 100% cpu for at least five minutes. killed LV and opened again. Now Install.vi can be opened. Tried installing again:
the folder <user.lib>\_express\UDB opens and LabVIEW is stuck in the taskbar with no displayed window and at 100% cpu for at least five minutes until I killed it.
Unpleasant experience.
Message 6 of 15
(4,549 Views)
In that case, I could try to load it up at home.  (Not sure they will let me do it at work, though.)
Bill
CLD
(Mid-Level minion.)
Message 7 of 15
(4,518 Views)
I broke the configure functionality just before I zipped it up (just t minor error flow "improvement. D'oh).
The there's an error flow issue with the installer: If LV is not run as admin, the installer can't update the user.lib; instead of throwing a permissions error, and invalid reference error comes out.
I've fixed both of those, but found a couple more installer issues.
This is a back burner project; but I'll get a fixed version out eventually.
Message 8 of 15
(4,513 Views)
You're always giving back to the forum.  THANK YOU!!!
Bill
CLD
(Mid-Level minion.)
Message 9 of 15
(4,509 Views)
Does somebody want to help out?  Here are the remaining issues:
  • In "Universal Dialog Box\Intstaller\Support\Place on Palette.vi", the call to "Write Palette.vi" fails.
  • In "Universal Dialog Box\Intstaller\Install.vi", If LV isn't running as admin, and you've clicked on paul_cardinale_0-1642865977081.png, then when you install, error 8 gets thrown right away.  I'd like it to check permissions whenever a folder is changed, and show a warning of some kind.  But paul_cardinale_1-1642866197596.png returns binary 111111111 on the folder even though it's not writeable.  What's the cleanest way to check that (or to check whether running as admin)?
  • When you do install to user.lib, it doesn't update "... \user.lib\dir.mnu".  Has anyone got a piece of code on hand to do that?
Message 10 of 15
(4,461 Views)
