Unknown running message about NuDAQmx Assistant
Hello All,
I got some problem about operate NI's USB DAQ 6009.
After I create a new VI with NuDAQ max item to get a DAQ Assistant block diagram.
I just go ahead to double-click the DAQ Assistant icon,
However, It seem suffer some unknown problem, then a messagebox illustration as follows:
=START=
Unable to locate the LabVIEW Run-Time Engine.
LVBrokerAux71 requires a version 7.1 (or compatible) LabVIEW Run-Time Engine.
Please contact the vendor of LVBrokerAux71 to correct this problem.
=END=
I try to check my add/remove tool in MSXP, there are both NI LabVIEW Run-Rime Engine 7.0 and 7.1
installed well. I try to reinstall the LabVIEW 7.1, but it does not work.
What the possible reasones about this? it is really annonying...
by the way,
I got some other program about these,
  NI DAQ 7.2, traditional
  NI DAQmx 7.3
  NI DAQmx Base 1.4, and so on...
Much thanks,
nonomiya
(2,508 Views)
Hi nonomiya,
seems that someone else got this message. Check out this: http://forumstage.ni.com/ni/board/message?board.id=170&message.id=102465
May be can be useful.
Paolo
Paolo
(2,499 Views)
