I got some problem about operate NI's USB DAQ 6009.
After I create a new VI with NuDAQ max item to get a DAQ Assistant block diagram.
I just go ahead to double-click the DAQ Assistant icon,
However, It seem suffer some unknown problem, then a messagebox illustration as follows:
=START=
Unable to locate the LabVIEW Run-Time Engine.
LVBrokerAux71 requires a version 7.1 (or compatible) LabVIEW Run-Time Engine.
Please contact the vendor of LVBrokerAux71 to correct this problem.
=END=
I try to check my add/remove tool in MSXP, there are both NI LabVIEW Run-Rime Engine 7.0 and 7.1
installed well. I try to reinstall the LabVIEW 7.1, but it does not work.
What the possible reasones about this? it is really annonying...
by the way,
I got some other program about these,
NI DAQ 7.2, traditional
NI DAQmx 7.3
NI DAQmx Base 1.4, and so on...
