07-03-2014 04:58 PM
I made an application with LabVIEW 64bits that use external DLL. I use this technique to load and unload the DLL from memory : http://digital.ni.com/public.nsf/allkb/77594203D78D12278625729100758BE5
When I unload the DLL from memory the application freeze.
If I don't use the Load Unload technique, my Application freeze when I close it and the Icon remain in the task bar.
It there any known issue about that for LabVIEW 64bits.
Anyone know a work around?
Thank you
07-04-2014 02:54 AM - edited 07-04-2014 02:58 AM
Yes I do. Fixing the DLL hang! ![]()
Most likely your DLL tries to do BAD things in the "process deattach". Microsoft specifically says that there are several things one should NOT try to do in a DLL when it is unloaded. One of them is for instance trying to explicitedly unload other DLLs that the DLL loaded previously. There are quite a few other operations that Microsoft strongly suggests to never try to do while the DLL is unloaded.
Basically when unloading a DLL Windows holds one or more locks to various system resources and several API calls can also try to get such a lock and if you are unlucky they will deadlock. This is much less likely if the DLL is called from a simple single threaded executable (which is often all a DLL developer dares to test if he even tests anything
) but LabVIEW is highly multithreading and there is a good chance to hit such a deadlock if a DLL tries to do BAD things in "process deattach".
The only thing you can try to do, which is by no means a guarantee that it should work, is to put all Call Library Nodes to execute in the UI thread. That can sometimes lower the chance to run in a system deadlock situation, especially if the DLL is itself using COM components that use Apartement threading or an even more restrictive threading model, but it is a bad band aid at best. Fixing the DLL is the only real remedy.
07-04-2014 07:46 AM
07-04-2014 10:39 AM - edited 07-04-2014 10:44 AM
Well, without seeing the DLL source all I can say is to look in the DllMain() function and in there specifically the PROCESS_DETACH case.
MSDN is very clear that one "must not" call LoadLibrary() and FreeLibrary() in PROCESS_ATTACH and _DETACH. That said it often works anyhow, but not always.
If you want to get more into dirty details of the NT loader/unloader you may find this series of blog posts interesting to read. But beware it is not suitable brain food if you are feeling tired or are annoyed about something. ![]()
07-04-2014 12:10 PM
