Unresponsive UI when plotting in log scale
Ok thanks for the suggestion. Anyway in this case I am not interested in the update time of the graph, it is only once it is plotted that everything becomes laggy when I use the log scale(even when the program is not running it is hard to scroll in the FP). That said your suggestion would be useful for me later when I need to plot and see the FFT in real time
Message 11 of 15
(1,354 Views)
Run VI Annalyzer.   I'd bet dollars to doughnuts you have overlapping FP objects.
Message 12 of 15
(1,352 Views)
Ok, thanks for all your help.
First, I replaced the code that you suggested,  I coded like that when I didn't know how to deal with 2D arrays and I left it.
Then, regarding the decimation adapted for the log scale, I get the concept, I just think that I don't know how to properly code it(I am not asking you to code it for me) I just thought there could be an easy solution, which seems that there is not.
I didn't really get your last answer, multipying the plot by a factor of 7, I just get a wider plot that takes 7x more space, what did I do wrong?
Overall, I really thought there would be a simple way to solve this problem inLabview, given that when you
plot an FFT yo use a large number of points to get a precise freq detection and almost every time you want it to be plotter in log scale. Seems that I was wrong
Message 13 of 15
(1,348 Views)
Ok, thanks for your suggestion, I have never used VI analyzer, will do it tomorrow
Message 14 of 15
(1,339 Views)
Multiply the plot width by 7, that is, if the width of the plot is 500 pixels, multiply that value by 7 and put it, 3500, into the decimation code as the plot width. Do not increase the plot size.
Message 15 of 15
(1,327 Views)
