Unused tunnels to While Loop
Thanks to everyone for your input.  I now understand what is going on.
To resolve the last couple of questions.  Yes, the wire going off to the right goes to the third loop.  The note was about the center of section of the block diagram I sent.  I took it out when I took the wires out and did not put it back when I restored the wires.  Obviously, I need to add that and many more notes as I clean up this code.
Thanks again.
Bill
Message 11 of 12
(776 Views)
Hopefully, you'll clean up the code in a way where that note is no longer useful and wouldn't need to be added back 😃
Message 12 of 12
(765 Views)
