Unwanted automatic promotion of .NET assemblies
Hi All,
I'm developing on a Windows 10 PC with LabVIEW 2016. The development PC has .NET framework 4.0 installed on it.  The target machine is a PCI chassis with a Widows 7 compatible controller ( running Windows 7) with the .NET 3.5 framework on it.
For configuration reasons, I cannot change the target machine, nor can I install the LabVIEW development environment on it in order to force LabVIEW to constrain to using .NET 4.0.
The problem is that when I try to select the System(2.0.0.0) to get the constructor that I want (System.Timers.Timer), I get a LabVIEW popup that states "The version of the assembly you requested was automatically promoted to a later version by the .NET runtime engine."  (NO. I WANT THE ONE I SELECTED!! STOP TRYING TO HELP ME MICROSOFT!!! - sorry)
Anyway, in doing research I have found within MSDN to turn off the auto promotion by adding the line "<AutoGenerateBindingRedirects>false</AutoGenerateBindingRedirects>" to the Visual Studio config file....  and all manner of "fixing" issue within MS products.
So I tried the following:
I have set the following on my development PC in a LabVIEW.exe.config file:
<?xml version ="1.0" encoding="utf-8" ?>
<configuration>
   <startup useLegacyV2RuntimeActivationPolicy="true">
        <supportedRuntime version="v3.5"/>
   </startup>
   <PropertyGroup>
   </PropertyGroup>
</configuration>
It does not help. I still get the same popup and when I build the executable and try to run on the target machine, it does not run, giving me the error that I need .NET 4.0 on the machine.
Any help on what I'm doing or not doing, wrong or right?
(4,510 Views)
Look at this NI article regarding your issue, perhaps it helps: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8XnSAK&l=nl-NL
Seems like it is a security issue. It goes further to explain how to load older assemblies: https://www.ni.com/docs/en-US/bundle/labview/page/loading-net-20-30-and-35-assemblies-in-labview.htm...
(4,500 Views)
With regards to the second link - I've used that solution for years and it is part of the config file that I posted in the original question.
I tried the actions of the first link and I still have the same pop-up stating that the dll has been promoted to the latest. I stopped LabVIEW and re-started it, but to no affect. Unless for some reason I would have to reboot the PC.
(4,483 Views)
You are right. I tried it myself, and I could not get it to work. However, I wanted to ask - Is your LabView version 32 bit? It does mention that the error can also occur if you attempt to load 64bit .dll into 32bit LabView.
(4,448 Views)
Hmmm - I missed that part.
My LV install is a 32-bit.
I would think for backwards compatibility, especially at the system level, MS wouldn't be developing dlls in 64 bit only, but...
But that also doesn't make much sense.  I want to use a system timer available in System.Timer. I'm trying to load / use the 2.0 version of the dll, but either Windows or LabVIEW is automatically promoting to 4.0.  I would imagine if anything, that the 2.0 version may still be in 32 bit and work properly.
At this point my team has a workaround in place, but I don't feel it's proper to be forced into using a dll that I may or may not want to.  If I'm forced to 4.0 this time, what happens in 2 - 3 years when I have to make a change to the code and I get forced to use System(6.0)? What ends up breaking in other parts of the code?
(4,436 Views)
Have you tried placing the "YOURAPP.exe.config" in your application directory with the appropiate name.  I have done this in the past to get my custom application to work with a certain version of .NET.
I had to have one in the LabVIEW directory and the custom application directory
C:\Program Files (x86)\National Instruments\LabVIEW 2019\LabVIEW.exe.config
YourAppPath\\YOURAPP.exe.config
(4,399 Views)
