10-10-2019 09:09 AM
Hi All,
I'm developing on a Windows 10 PC with LabVIEW 2016. The development PC has .NET framework 4.0 installed on it. The target machine is a PCI chassis with a Widows 7 compatible controller ( running Windows 7) with the .NET 3.5 framework on it.
For configuration reasons, I cannot change the target machine, nor can I install the LabVIEW development environment on it in order to force LabVIEW to constrain to using .NET 4.0.
The problem is that when I try to select the System(2.0.0.0) to get the constructor that I want (System.Timers.Timer), I get a LabVIEW popup that states "The version of the assembly you requested was automatically promoted to a later version by the .NET runtime engine." (NO. I WANT THE ONE I SELECTED!! STOP TRYING TO HELP ME MICROSOFT!!! - sorry)
Anyway, in doing research I have found within MSDN to turn off the auto promotion by adding the line "<AutoGenerateBindingRedirects>false</AutoGenerateBindingRedirects>" to the Visual Studio config file.... and all manner of "fixing" issue within MS products.
So I tried the following:
I have set the following on my development PC in a LabVIEW.exe.config file:
<?xml version ="1.0" encoding="utf-8" ?>
<configuration>
<startup useLegacyV2RuntimeActivationPolicy="true">
<supportedRuntime version="v3.5"/>
</startup>
<PropertyGroup>
</PropertyGroup>
</configuration>
It does not help. I still get the same popup and when I build the executable and try to run on the target machine, it does not run, giving me the error that I need .NET 4.0 on the machine.
Any help on what I'm doing or not doing, wrong or right?
10-10-2019
09:17 AM
- last edited on
12-19-2025
12:06 PM
by
Content Cleaner
Look at this NI article regarding your issue, perhaps it helps: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8XnSAK&l=nl-NL
Seems like it is a security issue. It goes further to explain how to load older assemblies: https://www.ni.com/docs/en-US/bundle/labview/page/loading-net-20-30-and-35-assemblies-in-labview.htm...
10-10-2019 09:34 AM
With regards to the second link - I've used that solution for years and it is part of the config file that I posted in the original question.
I tried the actions of the first link and I still have the same pop-up stating that the dll has been promoted to the latest. I stopped LabVIEW and re-started it, but to no affect. Unless for some reason I would have to reboot the PC.
10-11-2019 01:35 AM
You are right. I tried it myself, and I could not get it to work. However, I wanted to ask - Is your LabView version 32 bit? It does mention that the error can also occur if you attempt to load 64bit .dll into 32bit LabView.
10-11-2019 08:22 AM
Hmmm - I missed that part.
My LV install is a 32-bit.
I would think for backwards compatibility, especially at the system level, MS wouldn't be developing dlls in 64 bit only, but...
But that also doesn't make much sense. I want to use a system timer available in System.Timer. I'm trying to load / use the 2.0 version of the dll, but either Windows or LabVIEW is automatically promoting to 4.0. I would imagine if anything, that the 2.0 version may still be in 32 bit and work properly.
At this point my team has a workaround in place, but I don't feel it's proper to be forced into using a dll that I may or may not want to. If I'm forced to 4.0 this time, what happens in 2 - 3 years when I have to make a change to the code and I get forced to use System(6.0)? What ends up breaking in other parts of the code?
10-18-2019 02:28 PM
Have you tried placing the "YOURAPP.exe.config" in your application directory with the appropiate name. I have done this in the past to get my custom application to work with a certain version of .NET.
I had to have one in the LabVIEW directory and the custom application directory
C:\Program Files (x86)\National Instruments\LabVIEW 2019\LabVIEW.exe.config
YourAppPath\\YOURAPP.exe.config
