Upconvert VI Requests
Please use the Version Conversion board to post any requests to upconvert or downconvert your VIs.
In your post, please indicate:
Source LabVIEW version
Target LabVIEW Version
**Once converted, please mark the thread as Solved by selecting "Accept as Solution".
Please remember this is not a space for code discussion. This is just a space for you to post the VIs you need to be converted to an older or newer version of LabVIEW. If an issue arises where you need further assistance after the conversion has been completed (for instance, if you need the converted
VI to be removed from the forums) please select "Report to a Moderator."
Message 1 of 1,261
(34,873 Views)
smercurio_fc wrote:
A Downconvert VI Requests thread was created to try to keep all conversion requests from a newer version of LabVIEW to an older version of LabVIEW in one place.
While there is sort of a thread to post requests to upconvert VIs from LV 5.0 to 8.5, I figured a more general "upconvert" thread would provide symmetry to the Downconvert VI Requests thread.
Please use this thread to post requests to upconvert VIs from an older version of LabVIEW to a newer version of LabVIEW.
In your post please indicate:
source LabVIEW version
target LabVIEW version
Thanks for creating this thread, SMercurio!
Here is my request: some (not all) VIs in the attachment  are LV3.1, but my oldest installed LV is 7.1.
I'd be grateful if someone could convert them to LV 8.5 (or at least LV7.1)
-Franz
Message 2 of 1,261
(34,685 Views)
What's wrong with the 8.0 driver?
Message 3 of 1,261
(34,665 Views)
There's probably nothing wrong with that driver, but the LLB that I'd like to upconvert is a collection of my own VIs I wrote years ago, and already then (and still now) I preferred to write my own 'lean' drivers (lean= no VISA, plain IEEE488.2 code). Also some of the VIs in the posted LLB don't have a counterpart in the official driver suite...
So, if anyone could upconvert it, it would be great.
But  I'll have a look at the more recent  HP3458 drivers to see what they can do for me.
-Franz
Message 4 of 1,261
(34,651 Views)
Using VISA does not add enough overhead to really notice, imho, but to each their own I guess.Smiley Wink
Since converting from 3.1 requires the conversion kit (which is LabVIEW 4.0), you might have to wait awhile since I doubt very many users still have 4.0 installed. If you were to request the kit and post them in 4.0, it would be much simpler.
Message 5 of 1,261
(34,646 Views)
hi expertise,
anyone can convert the vi for sr760 for me? I can't find a local representative here.
Message 6 of 1,261
(34,630 Views)
Upconvert them to what version? Those VIs are written in 3.1, and as noted, you need either the conversion kit, or someone with LabVIEW 4. Besides, have you looked at the driver page?
Message 7 of 1,261
(34,621 Views)
Hi, I'm using LabVIEW 8.0. I wanna use this vi to perform some measurement on sr760. Yes, I've looked the driver page.
Message 8 of 1,261
(34,615 Views)
So why don't you just download the driver from there, which has a version for LabVIEW 8.0 instead of trying to upconvert something from 3.1?
Message 9 of 1,261
(34,568 Views)
Oh, b/c I'm so stupid.... Thanks!!!:smileytongue:
Message 10 of 1,261
(34,591 Views)
