Xcontrol size : not the same behaviour
Hi all,
I made an Xcontrol which adapts to the size of the window size. This Xcontrol contrains two graphs.
When the size of my window is small (about 800x600), everything is OK.
When I enlarge my window, the time response of my Xcontrol become verry long.
For exemple, I use the event XYgraph => mouse move to print the position of my mouse on the graph.
In the fist case (little graph), the value change 4 times per second.
In the second case (big graph), this value is updated one or two times per second.
Any Idea ?
V-F
(3,472 Views)
How big does the big window have to be for you to see this slow down? Does it happen all at once or is it a linear (i.e. A medium size window gives half-fast performance Smiley Wink )? Seriously though folks... Have you tried the same basic logic outside an xcontrol? Got any thing you can post?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,463 Views)
thanks for your help.
I think my problem comes from an amount of datas which is too big for rapid processing...
I'll try to clean my code, and will be back if it persists !
V-F
(3,447 Views)
