Update HMI VI while looping another VI
Good afternoon,
I'm trying to separate a VI in two parts : one doing a long process, the other showing gradually to the user the results of this process but I want to let the user cancel the process at any time. How can I do this ? I tried to call the HMI VI with an event structure IN but it's blocking the process. I also looked to do an asynchronous call but it doesn't helped me that much.
Knowing the interface is extremely simple and won't do complex tasks, it look like this :
Thank you in advance for your attention.
(2,518 Views)
Hi Martial,
learn about using queues and notifier (or wire channels), then place "process" and "HMI" into their own loops…
(2,514 Views)
I would like to also add User Events to this list.  I use User Events to pass data from the process loops to the HMI loop (which is mostly an Event Structure already).
(2,493 Views)
