Update Value after each flat sequence
Hi There,
I am trying to make a labview program do principal component analysis. My program is working fine but since it involves tons of calculation  it takes too much time and there is no way to know whether everything steps is going fine. I am trying to put some kind of progress bar thing in my front panel which tell me at what step the program is. The vi for progress bar i found works well with "for loop" but i do not have many for loop and but i my program have 6 step and i used flat sequence for each step. Is there a way to update value of slide after each flat sequence. I am using Labview 8.2 and i am attaching a image of a model vi that has a slide and has four flat sequence and each sequence has time delay of 1 second. I want that the value of slide update as data move from first flat sequence to next.
Thanks in advance
Yogesh
Message 1 of 9
(6,785 Views)
Accepted by Yogesh9ic
You can use a Local Variable for this...right click on the slide -> Create -> Local Variable.
Use one local variable each time you want to update the value.
Message 2 of 9
(6,781 Views)
Hi Yogesh,
locals or property nodes (which you can resize to allow more inputs...) will do...
Message 3 of 9
(6,778 Views)
Since no one else seems to have suggested it, why not use local variables?  🙂
Actually, if you really wanted to, you could also use a case statement inside a loop where each case was one of the frames in your sequence structure (use the iteration as the input to the case structure).  Then, you could have an output (for each case) tied to the progress bar indicator.  No local variables!
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 4 of 9
(6,774 Views)
May be a bit of an overkill, but you may want to try the JKI Progress Bar Dialog.
Message 5 of 9
(6,754 Views)
As above said u can use local variables and also property nodes.
What is difference between local variable and property node ?
http://forums.ni.com/ni/board/message?board.id=170&thread.id=206600&view=by_date_ascending&page=1
Find my sample programme i used both.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 6 of 9
(6,728 Views)
Example code as mattBradley suggested.(No locals and globals)
Balaji PK (CLA)
Message 7 of 9
(6,722 Views)
Thanks a lot for everyone's comment, I used local variable and it worked.
Message 8 of 9
(6,646 Views)
I guess you did not get the memo. Sequence structures themselves are not highly regarded either.
Message Edited by Dennis Knutson on 05-07-2009 01:48 PM
Message 9 of 9
(6,639 Views)
