 studentgirl
			studentgirl
			08-01-2016 01:40 PM
Hello everyone !! I have a slider numeric control and I want to be able to change and update the value when Vi is running. Can I use property node for this?
Solved! Go to Solution.
 RavensFan
			RavensFan
			08-01-2016 01:42 PM
Sure. Or a local variable.
These questions can be answered by taking those tutorials.
08-01-2016 01:47 PM
I was not able to find one which uses property node. Sorry about that.
 CoastalMaineBir
			CoastalMaineBir08-01-2016 02:25 PM
If it's a CONTROL (not INDICATOR), then it's intended for the user to set the value via mouse / keyboard.
You can still set the value via PROPERTY NODE or LOCAL VARIABLE, for ANY control.
What difficulty are you seeing?
 Wolleee
			Wolleee
			08-01-2016 03:41 PM
Heres an example for you.
 udka
			udka
			08-01-2016 03:47 PM
08-02-2016 10:26 AM
Sorry the problem is not solved yet. The horizontal slider control lets the user to choose the number of samples to display on the graph. The problem is when I run the VI and I change the value of samples through the slider, it does not update the values on the graph.
 Wolleee
			Wolleee
			08-02-2016 10:29 AM
Please post code and if you have another question it is good habit to start another thread  .
 CoastalMaineBir
			CoastalMaineBir08-02-2016 10:33 AM
You have shown NO code, so can you explain how anybody could possibly help?
08-02-2016 10:35 AM
The problem is that the code is confidential so I can't post it. But the only problem is that it is not updating the values in the graph.
