Update at wavechart from inside at subvi
A type definition?
Is there an example somewhere with the same issues?
Message 11 of 15
(1,057 Views)
@Michael.Koppelgaard wrote:
I have at subvi controlling mass flow controllers and reading pressure transducers
I want to see what's happening inside the subvi.
Therefore I want plot of flow and output from pressure transducers.
Why does it need to be in a subVI?  If you are writing so much to the GUI, then it should probably be in the main VI.  Or remove the loop from the subVI and put it in a seperate loop in the main VI.  That way you use data flow to write to the terminals of your indicators.
Message 12 of 15
(1,055 Views)
The type of the control ref in the sub VI is "dbl". You need to make a new control reference with the new data type. That will change the appearance of the value property node so that it takes a cluster.
Message 13 of 15
(1,039 Views)
Great  - now it worked.
thank you 🙂
Message 14 of 15
(1,021 Views)
I see you point - thank you for your advice
Message 15 of 15
(1,020 Views)
