Update cursor value programatically after graph's data change
After changing the Intensity Graph's value the old cursor value gets displayed.
How can I update the displayed value under the cursor programatically?
I dont want to move the cursor manually after graph's data update in order to display the value under the cursor.
CLA
(3,266 Views)
Play around with Property Node for the Intensity Graphy / Cursor.
(3,234 Views)
This is the solution I came up with. Was there something more elegant ?
CLA
(3,215 Views)
It would work correctly if you use a cursor that is locked to a plot instead of a free cursor. (See attached example)
(If you really want to use a free cursor, you probably need to tweak things with some property nodes whenever the value changes, not shown)
(3,211 Views)
Accepted by Quiztus2
Here's that third possibility.
(3,200 Views)
I didn't know that one can write consecutively in the same property node to the same value, interesting.
What is this block with the arrow before the unequal comparison?
CLA
(3,155 Views)
It's the "feedback node" from the "Structures" palette.
Greets, Dave
(3,133 Views)
