Update from 8.6.1 to lv 2009, lv missing vi errors, mostly DAQmx
Glad to hear that a reinstall solved the problem. Looks like the initial install got corrupted somehow. It happens, unfortunately.
Message 11 of 15
(1,132 Views)
I have the same problem.  Is it necessary to uninstall all of the lv components, or just lv 2009?
metzler CLAD
Message 12 of 15
(1,074 Views)
That's hard to say, since each situation is different. Try a repair first. If that doesn't work, then try reinstalling the DAQmx drivers. If that doesn't work, uninstall everything and reinstall.
Message 13 of 15
(1,061 Views)
okay, I have uninstalled all of the labview 2009 files, re-installed, installed the patch, and then installed daqmx 9.0.2 from a downloaded file.  I still do not have the daqmx files on the computer.  Is there a way I can just copy them from another computer, and have them show up on the pallette?
metzler CLAD
Message 14 of 15
(1,041 Views)
Hello Metzler,
When you run your DAQmx Full setup, make sure you have checked the LabVIEW 2009 support box. As shown in the picture.
Let me know on how it goes.
Good Luck,
NI-khil
Message 15 of 15
(1,024 Views)
