Update values in loop after pressing OK without leaving control
Point is, you didn't change the approach. It is incorrect to tight those two things together.
See attached example (LV 2014) for how you can address it.
Norbert
Norbert
Expert: Geometry
Message 11 of 15
(717 Views)
I can only open LV 2013 😞
Can you send a screenshot or resave in previous version?
Thx
Message 12 of 15
(714 Views)
This is easy (easier?)  Put it in the KeyDown event for Numeric and it'll look like you're updating while typing.
Jim
Message 13 of 15
(711 Views)
An alternative is to set key focus on another controller when pressing enter, return key.
See attached.
Message 14 of 15
(698 Views)
Thx
You might want to upgrade to 2014...The return key should register a value change event on the active and edited control, before togglin...
Message 15 of 15
(679 Views)
