Updating Labview.exe front panel from python
Hi
Is it possible to update a labview.exe front panel from python?
I tried this:
import win32com.client
labview = win32com.client.Dispatch("Labview.Application")
VI = labview.getvireference(r'python.vi')
VI.setcontrolvalue('Numerisch','5')
and it works fine. But when i replaced the python.vi trough a compiled python.exe i get this errormessage:
I tried this:
VI = labview.getvireference(r'python.exe')
Traceback (most recent call last):
  File "<interactive input>", line 1, in ?
  File "<COMObject Labview.Application>", line 2, in getvireference
com_error: (-2147352567, 'Ausnahmefehler aufgetreten.', (5507, 'LabVIEW', 'LabVIEW :LabVIEW:  Datei nicht gefunden. Die Datei wurde eventuell verschoben oder gel\xf6scht, oder der Dateipfad wurde bez\xfcglich Ihrer Plattform nicht korrekt formatiert. Beispiel: verwenden Sie \\ als Pfadseparator auf Windowsplattformen, : auf Macintosh u', None, 0, 0), None)
Is it possible to updating a labview exe front panal from python?
regards
Message 1 of 31
(11,862 Views)
Hi Iveco,
have you tried updating the value from another VI (not in the executable!)? I think you are calling the wrong application, i'm not fully positive about this but that might be a problem.
First make sure the VI-server is enabled, and the python.vi is exported.
Ton
My LabVIEW Ideas
Message 2 of 31
(11,861 Views)
Hi Ton
VI = labview.getvireference(r'C:\TEMP\python.vi')
this works fine. that means i can change the value in the python.vi. But when I compile the vi to python.exe it doesnt work.
How can I enable the vi server?
regards
Marcel
Message 3 of 31
(11,855 Views)
That should be done in the build settings, AND you should refer to the VI as c:\temp\executable.exe\python.vi
Ton
My LabVIEW Ideas
Message 4 of 31
(11,854 Views)
Hi all
It still doesnt work. I dont know why.
The current python code:
VI = labview.getvireference(r'C:\TEMP\python.exe\python.vi')
I registered with ccrpRegUtil.exe the builded tlb file.(Not sure its necessary)
Activex Server is active at the builder config.
when I change VI = labview.getvireference(r'C:\TEMP\python.exe\python.vi') to VI = labview.getvireference(r'C:\TEMP\python.vi')
and then I use the vi it works. with the compiled python.exe(with activex server)not.
I dont know maybe Im to stupid.
regards
Marcel
Message 5 of 31
(11,840 Views)
Thank you all for your help.
The Solution:
labview = win32com.client.Dispatch("Python.Application")
VI = labview.getvireference(r'c:\temp\python.exe\python.vi')
regards
Marcel
Message 6 of 31
(11,799 Views)
Excellent! I'm glad you got it working...
Since you are interested in this area, you might check out this example program. I know it is a side-step from what you are working on, but it's very interesting. The idea is to wrap the LabVIEW ActiveX Server into a .NET object and then use IronPython code to manipulate LabVIEW objects from within a LabVIEW VI! It's a neat way to blend textual and G code into one.
http://community.ni.com/examples/using-ironpython-from-labview/
P.S. This is from our new community sight. Feel free to look around or post any code that you created. Happy coding 🙂
Jarrod S.
Message 7 of 31
(11,796 Views)
accessing a control with python works fine, but how can I read/write a control wich is part of a "Tab"?
Marcus
Message 8 of 31
(11,479 Views)
Hi all,
I am new to this.
I want exchenge the data from pyton to labview and vice versa.
can u give the steps to do the above.
Please give with an example.
I amtrying really hard and i dint get the same.
Thanks in advance,
Yogesh
Message 9 of 31
(11,192 Views)
1. Unzip python.zip
2. Copy all files into c:\temp
    --> c:\temp\labview.py
    --> c:\temp\python.exe
    --> c:\temp\python.vi ......and so on
3. Open dos shell
4. change dir to c:\temp
5. Open Pythonwin
6. PythonWin: File Open c:\temp\labview.py
7. Run --> Ok
Now it should work
Message 10 of 31
(11,173 Views)
