Updating Labview.exe front panel from python
Hello sir ,
I am working on a project that controls the LabVIEW executable from python win32 com ActiveX
There is no problem in dispatching a vi.exe file but when I use getvireference I get the error open vi reference does not match the video in memory filename is no longer file may have own library LabVIEW error 6945 i am using the same method uuhave mentioned in your answer c:temp/.exe/.vi  wha is the reason for this please help regarding this matter as early as possible.
Message 21 of 31
(4,146 Views)
Hello sir , I am working on a project that controls the LabVIEW executable from python win32 com ActiveX There is no problem in dispatching a vi.exe file but when I use getvireference I get the error open vi reference does not match the vi in memory filename is no longer file may have own library LabVIEW error 6945 i am using the same method u have mentioned in your answer c:temp/.exe/.vi wha is the reason for this please help regarding this matter as early as possible.
Message 22 of 31
(4,143 Views)
Hi!
Had you any success with this? Because I'm trying to do the same!
I can access the .vi file, but not the executable.
Message 23 of 31
(4,045 Views)
When you create an executable in LabVIEW, you have to enable the ActiveX interface in the build settings under Advanced. And in there you also define an ActiveX server name. After installation of the executable on your machine (this is necessary to get the ActiveX server registered on your system) you then need to replace the "LabVIEW.Application" in your:
labview = win32com.client.Dispatch("<your ActiveX server name>")
You also need to make sure that the VI you want to access is enabled for remote access in your application ini file.
Rolf Kalbermatter  My Blog
Message 24 of 31
(4,041 Views)
Thanks for the tip, I will try it. So how should my ini file look like? What rows exactly should be included there to allow this? Could you help me with that? Currently this is how my .ini file look like:
server.app.propertiesEnabled=True
server.ole.enabled=True
server.tcp.paranoid=True
server.tcp.serviceName="My Computer/VI Server"
server.vi.callsEnabled=True
server.vi.propertiesEnabled=True
WebServer.TcpAccess="c+*"
WebServer.ViAccess="+*"
DebugServerEnabled=False
DebugServerWaitOnLaunch=False
Message 25 of 31
(4,038 Views)
server.tcp.enabled=False
The red entries are important in your application ini file.
The TCP server interface can be disabled with the green entry, unless you want to access VI server from another LabVIEW application through TCP/IP.
Message 26 of 31
(4,024 Views)
when I try to run it, I get this error now:
AttributeError: '<win32com.gen_py.LabVIEW 8.0 Type Library._IApplication instance at 0x48961352>' object has no attribute 'getvireference'
'getvireference' worked before, I don't know what happened.. I have pywin32 build 224 installed.
Message 27 of 31
(4,019 Views)
case sensitivity?
The method is called GetVIReference() but I'm not sure if the case matters when using python.win32com
Message 28 of 31
(4,012 Views)
Unfortunatelly it doesn't work with 'GetVIReference()' either.. buy the way how do I know which methods can I use for labview manipulation? I know only getvireference, getcontrolvalue and setcontrolvalue. Are there more? Where could I read about this?
Message 29 of 31
(4,006 Views)
Allright, I somehow solved the 'getvireference' problem, by reinstalling python..
So I can reach the .VI file again and read it's value once again.
I did everything as you said, I enabled ActiveX and named it, but when I give that name to Dispatch, I get this error:
Traceback (most recent call last):
  File "\anaconda3\lib\site-packages\win32com\client\dynamic.py", line 89, in _GetGoodDispatch
    IDispatch = pythoncom.connect(IDispatch)
pywintypes.com_error: (-2147221005, 'Invalid class string', None, None)
During handling of the above exception, another exception occurred:
  File "/Documents/Workspace/LaSo/Gateway.py", line 6, in <module>
    labview = win32com.client.Dispatch('Controller')
  File "\anaconda3\lib\site-packages\win32com\client\__init__.py", line 95, in Dispatch
    dispatch, userName = dynamic._GetGoodDispatchAndUserName(dispatch,userName,clsctx)
  File "\anaconda3\lib\site-packages\win32com\client\dynamic.py", line 114, in _GetGoodDispatchAndUserName
    return (_GetGoodDispatch(IDispatch, clsctx), userName)
  File "\anaconda3\lib\site-packages\win32com\client\dynamic.py", line 91, in _GetGoodDispatch
    IDispatch = pythoncom.CoCreateInstance(IDispatch, None, clsctx, pythoncom.IID_IDispatch)
Message 30 of 31
(3,994 Views)
