Updating Sub VI outputs
I've changed a sub VI buy putting another output on the form of the sub VI but the problem is when I insert the sub VI into the block diagram of another VI the new output does not appear on the block for the sub VI.  Is there a way I can update the outputs of this subVI????
Matt.
(3,284 Views)
Check Your connector pane to know that you added the additional input to the vi by selecting the Vi and press help.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,280 Views)
No it doesn't say I've added an extra output.
Matt.
(3,278 Views)
Accepted by gilgad2000
you have to "wire" the subvi connector.
Do do this: right click on the icon in the front panel window and select "show connectors". right click again and choose a pattern. Then you click a free connector terminal and the front panel element you want linkted to that terminal.
I hope that helped.
(3,271 Views)
