Updating a Control or Indicator of a Top Level VI from a SubVI
I am trying to pass the value of a subVI indicator to the mainVI indicator while the subVI is running.
At the same time I am controlling SubVI while Loop Stop condition from a control in Main VI.
(See Code Attached)
Stop button control is working fine, however the problem is that the indicator vilue is not passing to Main VI in Run time and is only passing after SuVI execution is over.
Is there iny mistake  in the code, or ther is a better way available to do this???
Please Help!!!
(4,274 Views)
Try to use without flat sequence ?
Use Functional Global Variable to transfer from sub vi to main vi during run time.
(4,264 Views)
Accepted by alt_234
You need to feed a reference to the meter that is located in the main VI into the sub VI through the connector panel as well.  In the subVI, you take in that reference and write to the value property node inside the subVI.
You basically did the exact opposite.
(4,252 Views)
Based on your attachment , you don't need to create sub vi .. single vi can do your job perfectly
(4,248 Views)
@RavensFan
Thanks!!!
It worked as you said (see attachment)
(4,183 Views)
