Updating a Control or Indicator of a Top Level VI from a SubVI
I am trying to pass the value of a subVI indicator to the mainVI indicator while the subVI is running.
At the same time I am controlling SubVI while Loop Stop condition from a control in Main VI.
(See Code Attached)
Stop button control is working fine, however the problem is that the indicator vilue is not passing to Main VI in Run time and is only passing after SuVI execution is over.
Is there iny mistake  in the code, or ther is a better way available to do this???
Please Help!!!
(4,263 Views)
Try to use without flat sequence ?
Use Functional Global Variable to transfer from sub vi to main vi during run time.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,253 Views)
Accepted by topic author alt_234
You need to feed a reference to the meter that is located in the main VI into the sub VI through the connector panel as well.  In the subVI, you take in that reference and write to the value property node inside the subVI.
You basically did the exact opposite.
(4,241 Views)
Based on your attachment , you don't need to create sub vi .. single vi can do your job perfectly
(4,237 Views)
@RavensFan
Thanks!!!
It worked as you said (see attachment)
(4,172 Views)
