Updating a case structure from pid output
Hi, Can you tell me where this "select" can be found?
Message 11 of 14
(796 Views)
Accepted by Rebel320
In the Comparison palette.  It looks like this .  Note that the search button in the palettes lets you search for a function by name.
Message 12 of 14
(785 Views)
Thanks for that, I can switch between modes now. Excellent, many thanks for your assistance and patience!
Message 13 of 14
(770 Views)
You should mark one of nathand's answers as the actual solution - not your thank you. Click on 'Options' above the message body to change the marked solution.
Message 14 of 14
(766 Views)
