Upgrading to LV 8.0 with PDA module
I have been using LV 7.1 and the PDA module; and while I'm quite happy with it, I would still like to upgrade to LV8. However, installing LV 7.1 with the PDA module was a real pain-in-the-*** - it takes a lot of time until you have everything installed in the correct order.
Therefore I am now wondering whether I can upgrade to LV8 without any further problems - will everything (including the PDA module) still work, or do I have to reinstall everything in the correct order?
cheers
  Martin
(3,248 Views)
LabVIEW 8 und LabVIEW 8 PDA Modul are full installer.
Labview 7.1 PDA has other requirements to the additional software (e.g. eMbedded Visual C++ 4.0 is required in SP 4 or later) --> to install LV 8 PDA is not so easy.
you must choose the right way of installation.
here a link with Information about PDA Module (Requirements on Software)
http://digital.ni.com/public.nsf/websearch/AF586D34790A379886256D73005CAF13?OpenDocument
Fabian
(3,208 Views)
Hi Fabian,
thanks for the post. I guess that means I should be able to upgrade to 8.0 without pain. I will try...
cheers
  Martin
(3,196 Views)
Hi i have labview 7.1 PDA module installer and it successful install but to upgrade it i have lost my 8.0 PDA driver . Is there any  possible way  to get installer from ni? i also have 8.0.1 PDA version cd but it ask for 8.0 first to b installed. how to fx the problem..i want to use it with labview 8.0..plz help
(2,613 Views)
