unwanted entry in table
I am stuck in a problem, someone might help
The table is giving unwanted entries in it.
Actually i have given condition that above some condition the entries to be filled , the conditoin is working but when the condition is false
the table displays 0 for that value, i also have to compulsary use the time stamp,
The vi is attached below
(3,083 Views)
What value are you looking for for the false condition? Right now nothing is connected so you will get the default value of 0.
PaulG.
Retired
(3,066 Views)
HI, Thanks for your reply
but i want to write the code for alarm condition so i dont want the false condition valus
If u think that the approach is right then can u suggest some for entry of data (alarm condition) with time stamp.
(3,040 Views)
Accepted by topic author sound nt
Hi soundnt,
   As asked previously in the post , the true condition you can do the file writing and since you want to leave the false values check the condition and write to file only for the true condition . For the false condition dont do an action or if you want to intimate put a notification logic to that .
Thanks and Regards
Pranchal
(2,993 Views)
Hi Pranchal
        Thanks for your reply, but i had tried it before but was not geeting the desired output
but after u replied  i once again gave it a try and got it
i think i have implemented it correctly but if u find any flaw kindly notify me the thanks
Regards
(2,977 Views)
