!!!Urgent: Boolean array to number!!!
I am trying to convert boolean array to number but I guess it has some limits. I have a boolean array containing 50 elements I want to convert that into number but it is not happening can anyone help. Its urgent.
(3,751 Views)
I got it. I changed the representation Array to number properties. 😄
(3,747 Views)
I don't understand what that means. Could you be a little bit more clear so others can learn too? Thanks!
(3,731 Views)
In a hurry I missed it. Let me explain now
1. I tried to convert a boolean array to a number as I had more than 40 elements I was getting only zero because of the limitation of I32 I know that I have to change the representation to 64bit but dont know where to do.
2. Then in the Boolean array to number function when I select the properties there I got the option for changing the representation to 64 bit. (This I totally missed when I was busy searchng a function outside to convert the output to a 64 bit value Smiley Sad)
3. Now I got what I expected. Smiley Happy
Thanks altenbach for asking.
(3,707 Views)
