installing or activating DAQmx
LabVIEW 2010 Full Development System, running under Windows 7.
Installed a PXIe-6363 multifunction DAQ card.
Recognized and tested fine under MAX.
No DAQ I/O functions in palettes, and any example vi's that seem to reference the 6363 return "missing add-on" message.
How to I install or activate DAQmx?
(2,865 Views)
You need to select "NI Device Drivers" from the installation, and that will show you available device drivers, including DAQmx. You can also install it separately. It should be on the DVD. You can also download it from the NI site (https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html)
(2,856 Views)
