Usage of Event Structure and push button
Look at the learning resources listed at the top of this forum.
Message 11 of 29
(919 Views)
You might also read my earlier message (#3 in this chain).
Message 12 of 29
(897 Views)
I have reviewed the topics you mentioned, thank you. I was wondering if you could recommend anything regarding elapsed time calculation? Kind regards.
Message 13 of 29
(892 Views)
There is a build in function for that:
Tim
GHSP
Message 14 of 29
(842 Views)
Since I mostly stay away from express VIs, I typically prefer to do my own timing, e.g. as described here.
Message 15 of 29
(835 Views)
Hello again,
Yesterday, I tried to understand the structure you shared with me and modified it to better fit my homework. I’m currently working on completing the required timing functionality. For that, I used the Elapsed Time block, but after making such a change, I started getting some errors. I’m trying to complete my assignment quickly, but I’m having a hard time fully understanding and resolving the structures I see online. However, with the feedback I receive from this forum, I’ve been able to make progress. Thank you all for your help.
In this step, I’m trying to make the program automatically stop if it runs continuously for 60 seconds.
Message 16 of 29
(831 Views)
Never ever modify a VI and attach it with the same name as a VI that I attached earlier. You need to give it a different name!
You also forgot to "save for previous". I cannot open 2025 VIs.
Message 17 of 29
(798 Views)
The changes of the time being exactly 60 secs is miniscule. Change to Equal or greater comparison. You can't wire 2 booleans directly to the Stop button, they need to go through a logical gate, i assume an OR.
Qestit Systems
Certified-LabVIEW-Developer
Message 18 of 29
(777 Views)
Hello again,
I have carefully reviewed the guidance you previously provided. I’ve also explored relevant forum topics, studied various resources, and watched several YouTube videos to better understand the subject. I’ve now reached the final step of my assignment.
In this step, I’m trying to implement a system where, once the Start button is pressed, the program counts 60 seconds. If the program runs continuously for 60 seconds without pressing the Stop button, it should automatically terminate. I tried designing a system that measures the elapsed time accordingly, but I encountered issues such as missing tunnel errors and red "X" indicators.
If possible, could you please make this final adjustment directly on the RunStopEvent.vi file you previously shared and send it back to me?
Thank you very much in advance for your help.
Best regards.
Message 19 of 29
(730 Views)
Hi dogukan,
Did you even care to read the previous messages in this thread?
(They contain a possible solution to your problem and the suggestion to downconvert your code to help us to help you…)
As you don't seem to follow our advice why should we solve your homework for you?
Yamaeda gave you the solution, you just need to read it!
Message 20 of 29
(723 Views)
