Usb voice missing in MAX
Hi everybody,
I'm trying to interface a M833 monochromator with my pc using labview. My system is actualy running
LabView 2010 sp1
MAX 5.0
NI-serial 3.8.1
NI-VISA 5.1
on Windows XP.
Opening the device manager my instrument shown (it's a plug and play device, and works good with factory softaware, so I think that drivers are ok).
In MAX in Devices and Interfaces are only listed:
-Network devices
-PXI
-Serial and parallel
What can I do to have usb voice in devices and interfaces in Max?
Thanks, uge
(3,262 Views)
Accepted by uge026
Hi uge026,
 Since your  M833 monochromator is not a NI Device and DAQ compatible,it cannot be listed in NI MAX.
uge026
Srikrishna
(3,256 Views)
What does voice have to do with your instrument?
If the product is the one shown at http://solarls.eu/products/2/16/25.html, then contact the vendor for the mentioned LabVIEW driver.
(3,240 Views)
Thanks for the answer,
is it possible anyway interfacing my instrument with labview even if is not present in MAX ?
I've got drivers from vendor ! Vendor's program (in labview) doesen't work, i thought because the instrument was not indexed in MAX ...
any idea ?
best regards
(3,237 Views)
You have to provide more information. What do you mean the vendor's program does not work? Error code/message that you get? Does the vendor provide a separate program and does that work? How exactly is the device listed in Windows device manager?
Without having the device or driver, the best place to solve any problems is with the vendor.
(3,221 Views)
The vendor provide windows drivers and a separate program and that works fine. Addictionally, vendor provides a test program and a library of control functions written in labview. Softwares in labview seems to be ok (no error messages are provided), but the instrument do not respond to labview-given commands.
I thought to a labview communication error, since vendor separate software works.
In the device manager, the instrument is listed as "stepper motor driver" (dunno why 3 times ... )
(3,213 Views)
Hi uge026,
  Can you please tell me in which language vendor's program is written?If possible can you please attach that file as well.
Srikrishna.J
Srikrishna
(3,183 Views)
