Use Data output of VI in Host as Input in Main VI in Target
Dear all,
I am new in LabVIEW and I would like your help if that is possible. As part of my master thesis, I have to use a project written by a PhD student several years ago. I am using LabVIEW 18 in windows 10 and a cRIO 9074 controller.
There are 2 main VIs in the project, MainSimple.vi running on the real time target and MainHost.vi running on the PC.
I attempt to run the MainSimple.vi but to achieve this a frequency table has to be loaded on the MainSimple.vi which takes values from a subvi called freqtablesTRIAL3VI.vi (which basically is a program that reads 110 txt files and converts them into a 2D numerical array).
However when I run MainSimple the table turns up with 0 values and I receive an error code 7 saying that file is not found and that I should verify that the path is correct even though freqtablesTRIAL3VI.vi works perfectly fine on the host.
I tried to move the folder in various locations in My Computer and inside cRIO using files transfer option in NI Max but nothing changed.
Then I attempted to run freqtablesTRIAL3VI.vi in the host and transfer the output on MainSimple.vi using a customized network shared variable but when I deploy it and run the Main I get errors. As I read it might be because I cannot enable the RT FIFO option due to the fact that my customized variable is a 2d array but I am not sure about it.
Then I thought to use network streams but If I realized correctly I can only use them to transfer data from cRIO to host and not the opposite direction (please correct me I have misunderstood).
So basically I am trying to find a way to use the data output from freqtablesTRIAL3VI running on my host as input in MainSimple. running on my target.
Any help on how can I achieve this would be greatly appreciated.
Sorry for the long message but I have lost a lot of time the last week running on dead ends.
I attach the 2 vis of interest and the frequency tables for your review.
Kind Regards,
Georgios
Message 1 of 10
(2,842 Views)
Personally, I would move your tables files to the cRIO in a special location.  Then update the freqTables VI to read in that location.  It is currently set up to read from the PC harddrive, which a cRIO does not have access to.  What you should really due is update that VI to have the path passed in.  Then your host and point to the location of the tables on the PC while the cRIO can point to the location on the cRIO.
GCentral
Message 2 of 10
(2,835 Views)
Accepted by amfetam1n
A Network Stream is unidirectional.  What this means is that data can only go in one direction.  However, you have have it goes from Host to the cRIO or the cRIO to the Host.  If you want to use Network Streams to go both ways, you need 2 Network Streams.  Personally, I just use the normal TCP/IP API to send data back and forth.
GCentral
Message 3 of 10
(2,834 Views)
I have a number of LabVIEW Real-Time Projects that use Network Streams.  I generally have a pair of Streams for "messages" from Host to Target, and from Target to Host.  Both Host and Target run code similar to the Queued Message Handler, with a specialized "Message Receiver" from the corresponding Network Stream used to "inject" a message such as "Here are the data you need for the cRIO" (which, of course, includes the relevant data read by the Host from its disk and sent as the "Data" Variant part of the Host-to-Target Message over the Network Stream).  The Target, of course, is also generating Real-Time data that can be saved directly on the Host if streamed (by yet another Network Data Stream) to the Host.
Message 4 of 10
(2,825 Views)
Just remembered that JKI recently put out a Network Streams toolbox that does the bidirectional communication with 2 Network Streams.  I haven't looked at it in depth, but it seems like it might fit this application.  JKI Network Streams Connection
GCentral
Message 5 of 10
(2,809 Views)
Hey crossrulz,
Thanks a lot for the quick reply first of all.
I moved my tables on the cRIO using the file transfer option through NI MAX. Then I updated the VI and run it on cRIO but I get an error message concerning my path(LabVIEW: (Hex 0x596) The path is empty or relative. You must use an absolute path.) even though I just copied it from the adress bar of the file explorer(it looks like this  ftp://169.254.84.198/ni-rt/Frequency%20Tables%20All%20values%2040to150/)
The VI runs but I get an empty 2D array with 0 values as u can see in the picture attached.
Cheers,
Georgios
Message 6 of 10
(2,806 Views)
You are using the wrong path.  See here for more details: Working with File Paths on Real-Time Targets
GCentral
Message 7 of 10
(2,797 Views)
Thanks for the link, I managed to finally pass the data from host to target using the network streams method.  I have an issue now however, that even though the data are read on the target as one can see on the output of probe 18 it doesn't get forward to probe 11 which is the wire that feeds the main loop of the MainSimple.vi. Do you have any clue why this can be the case?
Thanks again
Georgios
Message 8 of 10
(2,758 Views)
You aren't stopping the loop.  If you only expect the get the message once, then you don't even need a loop there.
GCentral
Message 9 of 10
(2,744 Views)
Thanks a lot, yes just managed to do it.
Message 10 of 10
(2,741 Views)
