Use LV to read data from a file that is already open in another program.
My operators use an office application where they pull up PDF and Word data sheets for various components that we test.
The URL looks like this:
http://team/Service/Motor%20Data%20Sheets/Forms/AllItems.aspx
I have no idea how to get to this from LV.
What I need: when an operator selects a document (PDF or Word) from this list I want LV to know what document was selected and have LV read the data from it.
PaulG.
Retired
(2,852 Views)
Hey Paul,
Are you trying to read text from pdfs and text files? Or are you trying to pull up the file into a window on the front panel of a VI?
Ian K.
Software Developer
Data Ahead AG
(2,800 Views)
I mistyped. It's not an office application but a Windows application that stores documents on our company intranet. The user clicks on a hyperlink of a document that can be either in Word or PDF format and it opens the document. I want LV to "see" this somehow so I can get the text data from the document. I realize this is more Microsoft/.net/magic than LV but was just wondering if anyone else has done something like this.
PaulG.
Retired
(2,785 Views)
Hi Paul,
You're right. There's a component in the .NET Framework which can solve this issue. You can use the FileSystemWatcher class to monitor access to files and folders. I think there's also a pretty good example for using this in LabVIEW.
http://forums.ni.com/t5/LabVIEW/How-to-trigger-an-event-when-a-file-is-created/m-p/2544613
Hope this helps.
Tyler.
Certified LabVIEW Architect
(2,778 Views)
