update service pipeline is down
I started to be unable downloading updates. I had similar problem with NI Update service about half year ago, it got solved then (ERROR: Errror updating Launch Condition Evaluator).
Now I see a different error msg:
log file:
[2013-10-07 15:31:42Z] ----------------------------------------------------------------------
[2013-10-07 15:31:42Z] National Instruments Update Service
[2013-10-07 15:31:42Z] Command-line: NIUpdateService.exe  -log log.txt
[2013-10-07 15:31:42Z] Version: 2.3.0.70
[2013-10-07 15:31:42Z] User locale: hu-HU 1038
[2013-10-07 15:31:42Z] Update Service language: en-US
[2013-10-07 15:31:42Z] Elevated: True
[2013-10-07 15:31:42Z] NiLmClient DLL loaded successfully.
[2013-10-07 15:31:42Z] NiLmClient DLL unloaded successfully.
[2013-10-07 15:31:42Z] License Manager: Update Service is enabled.
[2013-10-07 15:31:43Z] UpdateServicePresenter.CheckForUpdatesPressed
[2013-10-07 15:31:43Z] Beginning the process of checking for and evaluating updates.
[2013-10-07 15:31:43Z] Finished worker thread Ping Pipeline.
[2013-10-07 15:31:43Z] PluginRegistry.GetPluginsFromRegistry: Checking for registered plugins in the registry
[2013-10-07 15:31:43Z] PluginRegistry.GetPluginsFromDirectory: Loading plugins from Plugins directory: C:\Program Files (x86)\National Instruments\Shared\Update Service\Plugins
[2013-10-07 15:31:43Z] PluginManager.LoadAssembly: Loading plugin 'niusplfw' from C:\Program Files (x86)\National Instruments\Shared\Update Service\Plugins\niusplfw.dll.
[2013-10-07 15:31:43Z] DeviceFinder: SystemAPI version less than 5.5.0
[2013-10-07 15:31:43Z] PluginManager.LoadAssembly: Loading plugin 'niuspllc' from C:\Program Files (x86)\National Instruments\Shared\Update Service\Plugins\niuspllc.dll.
[2013-10-07 15:31:43Z] PluginManager.LoadAssembly: Loading plugin 'niusplmsi' from C:\Program Files (x86)\National Instruments\Shared\Update Service\Plugins\niusplmsi.dll.
[2013-10-07 15:31:43Z] An error occurred in worker thread Ping Pipeline: NI.UpdateWizard.Common.UpdateServiceException: Pipeline is down.
[2013-10-07 15:31:43Z] ***ERROR: Pipeline is down.
[2013-10-07 15:31:45Z] UpdateServicePresenter.CheckForUpdatesPressed
[2013-10-07 15:31:45Z] Beginning the process of checking for and evaluating updates.
[2013-10-07 15:31:45Z] Finished worker thread Ping Pipeline.
[2013-10-07 15:31:45Z] An error occurred in worker thread Ping Pipeline: NI.UpdateWizard.Common.UpdateServiceException: Pipeline is down.
[2013-10-07 15:31:45Z] ***ERROR: Pipeline is down.
[2013-10-07 15:31:46Z] UpdateServicePresenter.BeforeClose: Determine whether to prompt to confirm.
[2013-10-07 15:31:46Z] UpdateServicePresenter.StopWorkers: Stopping workers
[2013-10-07 15:31:46Z] UpdateServicePresenter.StopWorkers complete.
[2013-10-07 15:31:46Z]     Not downloading. Continue closing.
[2013-10-07 15:31:46Z] ----------------------------------------------------------------------
 What is this "pipeline is down" msg? How can I solve this issue?
Thanks for help!
Message 1 of 13
(3,917 Views)
Hello Blokk!
Does this error only occur on one specific machine, or on every machine in your network? Are outgoing connections blocked by a firewall?
  Georg
Message 2 of 13
(3,873 Views)
The problem only occurs on one laptop (Win7 x64), even if I disable firewall (Bitdefender 2013). I have another laptop (also win7 x64) connected to the very same LAN, and it can perform updates without any problem.
 When I started to encounter the problem, I had LabView 2012 on both machines. Since, I updated LabView to version 2013 on the non-problematic laptop. For my problematic laptop, I have licence for only LabView 2012, so I do not want to update it to 2013, but I would like to download and install patches automatically not manually.
Message 3 of 13
(3,870 Views)
Hi!
You can try to follow the troubleshooting steps in the following knowledgebases:
How Do I Resolve NI Update Service Secure Connection Errors?
Resolving NI Update Service Configuration File Corruption
Why Am I Getting an Error When Running My NI Update Service?
NI Update Service Does Not Update Software
You can also try to reinstall the NI Update Service:
NI Update Service 2.3
Regars,
  Georg
Message 4 of 13
(3,835 Views)
hello,
Actually I realized that, the NI downloader exe neither can reach NI servers. So probably firewall problem, even if I disable it? 🙂
http://digital.ni.com/public.nsf/allkb/95D8657558B6CED78625749100587D64?OpenDocument
I try the adviced steps, and soon back with results...
Even if I add the downloader exe to the Bitdefender exception list, or I turn off the Bitdefender firewall, I cannot connect.
So it is time to uninstall Bitdefender. If it helps, I will discuss this issue with the Bitdefender support.
Message 5 of 13
(3,826 Views)
hmm, I uninstalled the Bitdefender, and turned off Windows firewall...
Restart.
Unfortunately stucked, both NI updates and -downloaders still not working, no internet access looks like... But why only NI products have this problem on my laptop?? 😞
Message 6 of 13
(3,820 Views)
Hello Blokk,
I don't fully understand your last post. After disabling the security software on your computer, did you loose the internet connection completely?
Message 7 of 13
(3,777 Views)
No, I had internet access, all other software had access, except NI downloader and NI Update Service.
So strange...
I reinstalled the Bitdefender Internet security soft, since it was not the cause.
And I still do not have a working NI update.
Message 8 of 13
(3,772 Views)
Can you access http://www.ni.com and ftp://ftp.ni.com from your web browser?
Message 9 of 13
(3,770 Views)
yes, I can access both. Even I downloaded and opened a txt from ftp.
Message 10 of 13
(3,768 Views)
