Use Myrio analog output
Hi everyone,
I try to change the PWM output of this VI attached to AO. But I can not get anything from the AO1or AO0 port of Myrio.
(2,787 Views)
Hello CZ_Kevin
I opened the configuration of your PWM express VI however I did not see any channel selected. Could you attach your project?
Some basic steps to check:
 - Which terminal are you connecting?
 - Have you tried selecting a constant Duty cycle for testing?
 - Is your loop running fine?
 - Is there any error in the deployment process?
Please check these details first and if you are not able to find the problem you could attach your project so I could try to reproduce the issue.
Regards
Frank
(2,747 Views)
Here is the project attaced. I checked what you told you everything works fine. BTW how could I change it to multiple channles?
(2,712 Views)
