Showing results forĀ
Search instead forĀ
Did you mean:Ā
degree angle
plz, can i calculate sine and cosine angle in degree (not in redian), or there is any convertor from radian to degree
(5,920 Views)
What do you mean?  Is this question specific to LabVIEW at all?
 \text{angle in degrees} = \text{angle in radians} \cdot \frac {180^\circ} {\pi}
See here for the math behind converting Radians to Degrees: http://en.wikipedia.org/wiki/Radian#Conversion_between_radians_and_degrees
If someone helped you out, please select their post as the solution and/or give them Kudos!
(5,917 Views)
yes exactly , i mean there is no a direct block to do this and producing the cosine or sine in degree instead of rad
i must  build it from this equation?
(5,907 Views)
Accepted by topic author ssara
Hello ssara,
LabVIEW provides two built-in functions to convert from radians to degrees and vice-versa:
LabVIEW Help: Radians to Degrees
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/baseanly-llb/radians-to-de...
LabVIEW Help: Degrees to Radians
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/baseanly-llb/degrees-to-ra...
I recommend searching for an answer before posting - these are two of the top hits when searching "radian to degree LabVIEW" in a generic internet search engine.  They are also available via the Numeric Conversion palette and are easily findable using LabVIEW's built-in search functions:
LabVIEW Help: Searching for Controls, VIs, and Functions on the Palettes
http://zone.ni.com/reference/en-XX/help/371361K-01/lvhowto/searching_for_controls_vis/
Tom L.
(5,906 Views)
thank u Tom
regards
(5,885 Views)
