Use Old Bitstream option disappeared for FPGA compile/run
We are using the Labview FPGA Module.
Somehow my co-worker has disabled the Use Old Bitstream option dialog from appearing.
It is really annoying to have to recompile when only making a cosmetic change.
Anyone know how to restore this dialog box?
I have looked everywhere, including the registry.
It has disappeared for all users.
(2,581 Views)
it must be cathartic to post a message to the discussion forum since i found the solution
2 minutes later (after 20 minutes of searching Options, ni.com, etc.):
in Labview.ini
make the following change
nirviShowCompileWarning=TRUE
(2,577 Views)
