Write string to file
I have been looking around in this forum for similiar threads about writing to files and also tried a few of the examples in Labview 7.1.
Unfortunatly, my beginners experience is not enough for making any thing useful of the above mentioned.
My question; I have an app. that is sending a string, build up from combinations of strings to a device over RS-232. The strings is received fine and everything works. But I would like to read the settings in the device to a file on the computer so that I later can download the settings. Therefore I am wondering what would be the best solution for taking in a string and save it to a file;
The string that is presenting the settings, is recieved (after a sent command of #1KI01 for channel 1) in a format of  #1KI010000327683000, where I would like to extract #1KI in the beginning and then save the rest to a file. After that, I send another command (#1KI02 for channel 2)  which gives the string for ch. 2 and so on.
When I read it back, it must be in string form in the format as recived, but with SK instead of KI inserted.
The best would be to save it to an *.txt file, but I am not sure how to get it working, my efforts gets me stuck on what VISA to use, write to file, write to spreadsheet or write chars to file , and is the preferable way in Labview to work with data like this, to convert the strings into an array?( newbie problem Smiley Happy )
Any hints on getting started would be appreciated, the course in December is just to far away right now...
Many thankful regards
Beagles
(2,941 Views)
This on is free to get you start.  Try looking in LabVIEW -> Help -> Find Example.  Many good starter programs are there.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,925 Views)
