Use default if unwired buggy?
Hallo,
I have case structure with several outputs (clusters, refnum,...). Since
there are cases where I don't want to have these wired I've checked the
"Use default if unwired".
But still LV tells me that the VI has "Tunnel: missing assignment to
tunnel" errors.
What's the problem ?
Thank you
Oliver Friedrich
(3,094 Views)
Hello Oliver,
As you mentioned that you have case with several outputs, there might be one or more output for which you have not enabled "use Default if unwired" option. This happens incase your wiring arrangement is not proper i.e. improper alignment, arrangement or clumsy. Just check thoroughly by putting the proper alignment of all the output wires.
Hope this helps. Your feedbacks are welcome.
Best Regards,
Nirmal Sharma
(3,094 Views)
