Using Data Socket with LabView 7 Image Display
I want to to connect the Image Display over the Data Socket, but its not working?
(3,491 Views)
Please be more specific. How are you trying to connect to the datasocket. is it over a network. same PC.
Joe.
"NOTHING IS EVER EASY"
(3,491 Views)
I am not sure it is possible to send the image data type directly over Data Socket.
I would give it a try sending the image as 2D array (using the Image to array function) or converting the image to a Variant and rebuilding it on the other side with set Variant to Data vi.
(3,491 Views)
