Use listbox symbols in the help text
In a GUI I use the listbox control and indicate some status information with the item symbols.
Now I want to add a help file / control description and would like to explain the symbols..
I searched the system symbols / windings etc, but I didn't found all items I used Smiley Sad
Did I overlooked them somewhere?
Someone some other idea(s) than capture a screenshot and cut them out ?
BTW this application is LV6.1
Greetings from Germany
Henrik
LV since v3.1
(2,437 Views)
No ideas other than taking screenshots, but if you end up taking screenshots this program is great and has a nice long free trial:
It'll let you capture the window from the listbox symbol constant which will give you all of them at once, or you can set its capture mode to fixed region and use that to get equally sized captures of each symbol.
(2,434 Views)
