You can download the current runtime engine from ni.com. Install it on the PC that you are running on. Or you can create a exe that has no code, just a blank vi compiled into an exe and under the installer options you can include the runtime engine to be installed. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
