Use regular expressions to extract .llb filename from path
I am trying to be clever (always a dangerous thing) and use a regular expression to extract the name of a library from a filepath converted to a string.   Whilst I appreciate there are other ways to do this, regex would appear to be a very powerful neat way, should I be able to get it to work.
i.e if I have a string of the type, C:\applications\versions\library.llb\toplevel.vi, I want to be able to extract library.llb from the string, given that it will be of variable length, may include numbers & spaces and may be within a file hierarchy of variable depth.   In other words, I want to extract the portion of the string between the last \ that ends with .llb
The best I have managed so far, is \\+.*llb which returned everything minus the drive letter and the toplevel.vi
Can anyone help me achieve this, or am i better using an alternative method (e.g filepath to array string, search for .llb)
Matt
(4,204 Views)
Accepted by topic author Zedd
Hi Matt,
attached you'll find two other options.
Mike
Message Edited by MikeS81 on 04-13-2010 01:30 PM
(4,198 Views)
Thanks Mike.
I sometimes get distracted by trying to create 'elegant technical solutions' and fail to see what's staring me in the face.   Option 2 does the job nicely.
Matt
(4,177 Views)
Disclaimer: The solutions posted by MikeS81 are the preferred method to parse out file paths.
But I love a regular expression challenge.
Try
 [^\\]+\.llb
Omar
Omar
(4,161 Views)
Thanks Omar, that'll work nicely too.
I've never really played with regular expressions before, but they do look like a really poewrful tool, which is why I was trying them out here.   Got stuck by my lack of knowledge.   You wouldn't happen to know of a decent tutorial / book  that covers how to build these ?
Matt
(4,148 Views)
