Use spacebar to toggle in key navigation
I want to use the spacebar as a start stop button in my application. It's not listed under key navigation is there a way to do it programmatically?
(5,571 Views)
Accepted by Viper
You could use an event structure with a Key Down event for the VI.  Compare the Keydown with the space character and act accordingly.
(5,565 Views)
How do you determine what key was pressed?
(5,562 Views)
The terminals inside the event case have Char and Scan Code, you can read either one and compare it to the value for space (Char =32,  Scan Code = 57)
(5,557 Views)
That did it!!   thanks
(5,547 Views)
