Use switch to cut a waveform
I try to cut a waveform when the curve value is greater than a threshold value.
I use a switch and I generate the cut signal 0 (FALSE) for return 0  and 1 (TRUE) to return the value of the waveform.
But I have a null waveform as result !!
Do you have an idea because when I use a switch on the front panel, the result is well but manual !
See attach files.
(3,108 Views)
Accepted by joc31
I am not sure if I understand you problem correct. But see if this VI helps
Y[i]=Clip{X[i]} VI
Owning Palette: Signal Operation VIs
Installed With: Full Development System
Clips the elements of Input Array to within the bounds specified by upper limit and lower limit.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,105 Views)
I have modified Vi with clip and It's work fine.
Thank you very much.
(3,091 Views)
