User defined alarm - Invalid Argument
Why does this code give an error.  I copied it directly from the example.  My first thought was that I had to create the process first.  This was not the case.  It could be the user input.  If it is, how do I know what the username is?
Matt
(2,715 Views)
Hello Matt,
The problem is not clear to me, what error are you seeing?
Eric L
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
(2,692 Views)
Accepted by Mattjk
The problem seemed to be that when you run it the first time the VI generates a user defined alarm and when you run it here after, an error is generated because the first alarm hasn't been acknowledged.
(2,681 Views)
