I did select VI Properites--> window size --> Maintain proportions ... and Scale all objects,
But I think the problem is the fonts size is fixed, so even before I build executabe file, I resize the VI window, I will see the objects are all messed up (see attachment)
This should be a pretty common problem. Anybody know a solution?
DG
