Using APFI0 with NI PCI-6259 and BNC-2110: Error 200284
I am trying to do a triggered dataaqusition with a NI PCI-6259 and BNC-2110 using the APFI0. To test this setup I use the example "Acq&Graph Voltage-Int Clk-Analog Start w Hyst.vi". The triggersignal is connected to the APFI0-Input of the BNC-2110.
Software Configuration
Physical Channel: Dev2/ai0     (6259 Channel 0)
Trigger Source: APFI0
Slope: Rising
Trigger Level: 0
Hysteresis Level: 0
I always get the error "Fehler -200284 ist bei DAQmx Read (Analog 1D Wfm NChan NSamp).vi:3 aufgetreten".
With the combination of  NI PCI-6115 and BNC-2110 it works without any errors.
Physical Channel: Dev1/ai0     (6115 Channel 0)
Trigger Source: PFI0
Slope: Rising
Trigger Level: 0
Hysteresis Level: 0
Where is my error using the NI PCI-6259?
Thanks a lot and best regards,
Michael
(2,929 Views)
(2,921 Views)
