Using IMAQ Cast Image to convert 16 bit to 8 bit image.
I am trying to convert a 16 bit image to a bit image, and I am using IMAQ Cast Image. I am wondering what I am supposed to wire into the # of shifts? When I use NI Vision Assistant it asks I can convert by the adjust dynamic method. Does anyone know how to do this with IMAQ Cast Image? Thank you in advance.
(3,508 Views)
The number of shifts is the number of bits that will be chopped (in the dark regions) from the initial image to fit into 8 bits.
For instance, if you have a 10 bit image, compressing into an 8 bit image will obviously introduce some losses. You can decide to loose information either in the "whithe" parts or in the "black" parts of the image.
With #shifts = 0, the two most significant bits will be lost, so the whitest parts of the image will be uniformely white, but the darl grey levels will be preserved.
With #shifts = 2, the two least significant bits will be lost, preversing the whitest parts grey variations, but losing the subtilities in the darkest parts.
With #shifts = 1, a single bit is lost on either sides...
Chilly Charly    (aka CC)
(3,501 Views)
