Using Keyboard to trigger digital output
I have a motor which I currently control using digital outputs on the front page, however, I was wondering if it would be possible to link this to the up and down keys on the keyboard?
Thanks in advance for your suggestions.
(1,902 Views)
Accepted by Max2796
One quick try is to right click on the Boolean Button and select  Key Navigation
You can then select a list of options of keys that you can assign to the Boolean button.
Give it a try and see if works.
(1,894 Views)
Thanks for the quick response LVNinja - worked perfectly.
(1,885 Views)
