Using LabVIEW with MCC daq
Hello:
I am trying to connect my DAQ to LabVIEW. I am using the guide that you can find attached, and a tutorial on youtube (https://www.youtube.com/watch?v=GqyooarvbuM). However, I am not able to do it properly. Since I have a the following error: SubVI 'ULx Create Virtual Channel.vi': required input 'physical channels' is not wired. Moreover, when I select the function "create Channel" I got 30 warnings, I think because the name of the folder is different from what expected (LabView 2013 instead of LabView 8.5).
Can someone help me?
Gianmario
(7,958 Views)
Accepted by topic author GM1710
Hi Gian,
- you need to wire required inputs of subVIs!
- warnings are just warnings - they are no errors: as long as the functions work as intended you can ignore them…
(7,953 Views)
Thank you!
(7,918 Views)
Can you please elaborate on this.
The physical channels are not detecting on my MCC DAQ.
(7,168 Views)
Hi Manjunath,
I guess it is me you are calling "you"…
When your "MCC DAQ" does not detect any "physical channels" then either your "MCC DAQ" is broken or your software installation is not valid!
Do you mind to provide more information? Which DAQ device do you use? Which MCC software did you install? Which LabVIEW version do you use?
(7,161 Views)
Device : MCC DAQ USB 1024LS
Software : INSTACAL and DAQami
Version : LabVIEW 2018 using MCC Ulx for NI LabVIEW
(7,142 Views)
Hi Manjunath,
does InstaCal show the expected results? (Is ULx installed correctly?)
(7,132 Views)
