Using Month Calender of .net in Labview .
Hi ,
 I am using month calender from .net & Activex pallete in a vi.I getting warnings , which i am sending as screenshot. When i create a exe , it giving error & not creating exe.
I have .Net 2.0 runtime. The System.Windows.Forms.dll is there in GAC. But still it is giving warnings when vi is run and not creating exe. I am using Labview 8.5.
Is there any thing to be done to use .net controls in labview.
If you put NET Meetings Calendar.vi (which is there in ni example finder) in a project and create a exe , it will give error and not create exe.
I am attaching the sample project with vi.
regards
Santosh Kumar
Message 1 of 17
(5,969 Views)
Hi Santosh,
I opened up your project and compiled it in 8.5.1 with your build specification with no errors.  Maybe something is misconfigured with your .NET framework?  I'd recommend removing and reinstalling this, or (if possible) try compiling your project on another system to see if you can reproduce the error.
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
Message 2 of 17
(5,914 Views)
Also, the warnings don't appear to be a problem.  I opened your vi, saved it, closed it, and re-opened it and the warnings did not appear again.
Eric V
Message 3 of 17
(5,913 Views)
HI Eric,
 After installing Labview 8.5.1,  the errors i mentioned above , didn't occur.Exe gets generated.
 The exe generated was for a different project , in this project i have vi's having month calendar of .net (operator log.vi and Read system log from file.vi ) as control.But after creating the exe , and running the exe. I got the following error "Labview needs more memory to compile vi". What's may be the reason . In development mode there is no error at all.The src code does not give any such errors. I am attaching the scrrenshot of the error.
regards
Santosh Kumar
Message 4 of 17
(5,887 Views)
Santu,
I have not experienced that error either.  This help file provides more info:
LabVIEW Help - LabVIEW needs more memory to compile VI
You may also want to try creating a debuggable exe:
LabVIEW Help - Debugging Applications and Shared Libraries
Eric V
Message 5 of 17
(5,834 Views)
Hi Eriq,
The help does not say much about the error ,It says "There is insufficient memory available. To correct this error, you must make more memory available on your computer for LabVIEW to generate the code for this VI."
Anybody facing such situation, and found a solution ?
regards
Santosh Kumar
Message 6 of 17
(5,762 Views)
Hi Santu,
Then, does that mean this error occurs when you double-click the EXE?  If that is the case, have you tried making it debuggable and connecting the development environment to see if the error still occurs?  Could you post the EXE here?
Eric V
Message 7 of 17
(5,739 Views)
Hi Eric,
Yes when u double click the exe ,the error occurs .I am attaching the exe.Just rename Application.txt to Application.exe.I have not tried making it debuggable.
regards
Santosh Kumar
Message 8 of 17
(5,720 Views)
Hey
Can't able to convert your txt to exe. How you did that?
Mathan
Message 9 of 17
(5,713 Views)
Ok fine,
I did it in DOS prompt.
Message 10 of 17
(5,710 Views)
